Tuning Nightmare Help
Old Aug 22, 2008 | 04:03 PM
1INSANEGTO's Avatar
Originally Posted by ramairws6
Check the Maf like said above. Also, do you have a timing tuner? I see you have nitros so I assume you have something like this? The reason I ask is that I had an issue of the exact same nature and what happened was the wiring for the Timing tuner melted and grounded against the block down by the crank sensor. Odd but it did the exact same thing yors is doing! Worth a shot? Traver
Funny you say that cause when one of the codes were pulled it did say a the crack sensor. Yes it the NOS Nitrous Timing Controller with the LCD touch screen. I will follow up on that as well.
Old Aug 22, 2008 | 04:04 PM
1INSANEGTO's Avatar
Originally Posted by minytrker
I may have missed it but did you try to run the orignal tune that came in the car again?
Yes Mike saves all the tunes before he tune for issues like this.
Old Aug 22, 2008 | 04:08 PM
1INSANEGTO's Avatar
Originally Posted by LS1-450
Yah, the simple unpluging of the MAF & filter oiling are only noted two posts above yours. 1INSANEGTO, where are you on this?
Where am I at? hmmmm I was in Etten Lure Netherlands Mon and Tuesday Amsterdam on Wed Milan Italy Wed Thur & Fri and now I am sitting in Amsterdam and head back to the US tommrow. BTW its 11:07pm here and everytime people walk past me smoking it smells funny
I will follow up and all this good info this weekend and I will check back in on monday.
Old Aug 22, 2008 | 08:08 PM
Mean Green z28's Avatar
So you swapped interiors and then it started acting crazy? The PCM is not gonna drop a tune 'cos you disconnected the battery. Did you drive it right after the interior swap?
I'm gonna go out on a limb here 'cos everyone's answered a lot or Tuning related questions ....
I don't know too much about the GTO's but do you think that anything was left unplugged when you swapped the interior? Were the seats switched? Do the seats have vacuum/air lines going to them like in the f-bodies? I'm just wondering if it's something as simple as a vacuum leak that started the whole ordeal and messed up the O2 sensors/etc. by the fuel trims dumping too much fuel ... okay, now beat me to death
Old Aug 22, 2008 | 09:38 PM
Viper's Avatar
I'll throw this out; what shape is the battery in? If it's not good it could give lousy voltage. Just a thought; swap one with someone else as it's cheap to try.
Old Aug 23, 2008 | 12:02 AM
1INSANEGTO's Avatar
Its a redtop.
Old Aug 23, 2008 | 10:55 AM
LS1-450's Avatar
I used to travel a lot for work as well. Hated every second of it. Jet lag, crowded air planes, no sleep for days @ times. Then arrive home where everone assumes you've had some kind of vacation.
Old Aug 24, 2008 | 01:28 PM
1INSANEGTO's Avatar
With or Without tbe maf the car runs like crap and the a/f is everywhere.I will check the wiring next once it cools off
Old Aug 24, 2008 | 02:44 PM
Viper's Avatar
Quote: "Its a redtop."
I had a redtop and it died within one year.
Old Aug 24, 2008 | 06:09 PM
1INSANEGTO's Avatar
Battery is fine.
Old Aug 24, 2008 | 06:54 PM
LS1-450's Avatar
Have you checked the injectors & spark?
Old Aug 25, 2008 | 05:14 PM
  #32
Slowhawk's Avatar
LS1Tech Sponsor
Without seeing the car I'm going to say it's the MAF. Sounds just like a problem I had recently. Had a SLP MAF and needed a 50% change to the MAF curve over stock. Threw that POS in the garbage can. But it did the same thing.Ran fine for awhile then went to ****,then fine again.
Old Aug 25, 2008 | 06:39 PM
  #33
joecar's Avatar
We took it out on some back roads and made a few N/A passes and nitrous hits. Everything was fine per the AEM wideband. Well the wife wanted all black leather interior so we had a friend to swap with. Well in order to not get a airbag light during the swap which is typical if you do not disconnect the battery. So we disconnected the battery and made the swap.
Was the key off when the battery was disconnected and later reconnected...?
Old Aug 25, 2008 | 08:42 PM
  #34
1INSANEGTO's Avatar
Yes no codes.
Ok all I think I might have found the issue. I rem when I was at Gforce mike and joe seen that my catch can was hooked up wrong (prev owner install) so they fixed it for me. Ok now my point. When I pulled the intake I did notice oil in the chambers of the heads and did not think nothing of it till today. I went and had the codes read and guess what a map sensor code so and a few others so while at the store I got a new one. Well pulled the old one and guess what there is oil on it so I think hmmmmmmm let's check this oil catch can. Guess what its full!!!!!!!!!
Think I solved it? This would explain while it was tuned before and went to crap and why all cylinders were going lean and the wideband going crazy
Old Aug 25, 2008 | 10:02 PM
  #35
Crowder's Avatar
ive had the same problem before, it was my rc injectors, try tuning 1000cc's on a 2.0 4 cyl turbo car and get it to idle with 1 bad fuel injector
Old Aug 25, 2008 | 11:19 PM
  #36
Alvin's Avatar
I'll bet I know exactly what it is...
http://www.hptuners.com/forum/showth...=rear+GTO+lean
When you disable the rear o2's in a GTO the computer can do some funky stuff on you.. Like go extremely lean in cruise.
I'm not sure if the 04 will do it but the 05's definitely have this issue. Maybe its an auzzy thing
Old Aug 26, 2008 | 07:21 AM
  #37
1INSANEGTO's Avatar
however can hptuners explain this????
Old Aug 26, 2008 | 11:47 AM
  #38
LS1-450's Avatar
OK, so has the new MAP sensor solved the problem? If not, what were the other codes?
Old Aug 26, 2008 | 12:17 PM
  #39
1INSANEGTO's Avatar
idels high and there was a code for that. Lean bank. But the reason for the high idel could be the valve is stuck or gunked up or something so I am going to take the throttle body off and clean that and the MAF. It does run but can it be tuned. I am waiting on my hptuners so I can get some logs.
Alvin- After reading that it might be a issue and I will address it. I know that only one rear O2 in there as the prev owner took the other one out and put the wideband in there.
Old Aug 26, 2008 | 03:41 PM
  #40
1INSANEGTO's Avatar
Ttt.......................
