5.3 Lean Condition Help?..
I have an 03 Suburban 5.3 w/ 65,000 miles thats giving me lean condition codes for both banks.
I have cleaned the MAF and since its both banks I assume O2s are not the issue. The main symptom is that every once in a while at a dead stop idle in gear it will drop way down in idle and rpms will bump around like a small misfire. It hasnt ever died, just really stumbled low. As soon as I touch the gas it smooths right out. All other drivability is great.
Not real sure what to look at and I dont want to just start throwing parts at it. Any advice on what items to take a look at?...Thanks!
I work at a GM dealership and have replaced many of these gaskets for leaks. There was a design change too. The newer GM gaskets have green sealing rings on them. They aren't cheap either. Good luck.
well.......................... looks like its time to Rinse and Repeat
