EFI Live ?
Old Aug 21, 2008 | 11:18 PM
Sparkinak's Avatar
Default EFI Live ?
I got a computer off ebay and had it tuned with the basic stuff removed. I got it in the truck and it ran all right. So I then purchased EFI Live. Found out it wasn't programmed like I was told it was. Before I touched it, it didn't have DBW. Now that I programmed it, it now has DBW. All I did (at least think) was segment in a 6.0 and a 4l60e and kept the VIN that came on the PCM. How do I remove the DBW setting cause thats the only thing holding me back from driving the truck...
Kevin
Thanks in advance.
Old Aug 22, 2008 | 06:08 AM
ssvolvo's Avatar
http://forum.efilive.com/
Old Aug 22, 2008 | 12:28 PM
LuvmyC5's Avatar
You might want to pm Jesses Bubb@ Wait4me performance.
Him and Chad are the EFiLive gurus and I'm sure would have the fix for your problem.
Good Luck!
Old Aug 22, 2008 | 09:18 PM
Sparkinak's Avatar
Originally Posted by ssvolvo
Yeah that wasn't any help, I looked and got nothing...
Sparkinak's Avatar
Good Luck!
Emailed 2 weeks ago and haven't gotten a response. Working 12's and don't have the time to call.
Old Aug 23, 2008 | 07:19 PM
mvvette97's Avatar
what's DBW?
Old Aug 23, 2008 | 07:37 PM
macca_779's Avatar
Drive By Wire.. Got me stuffed why people are calling it that as it is referenced as ETC usually.
Mate don't worry that you have the ETC folder come up. Its normal for when you plug the V2 in. It happens like this to prevent guys that only have the Demo Version of EFI LIVE from accessing the ETC data.
Old Aug 23, 2008 | 07:38 PM
SS2win's Avatar
Are you sure it's active?? THe software warns if the parameters are not valid. Hopefully that's what you're seeing.
Old Aug 24, 2008 | 01:37 AM
Doc's Avatar
Doc
To the OP, send me a copy of the tune and I am sure we can sort it out.
doc@efialchemy.com
Old Aug 24, 2008 | 01:41 PM
Sparkinak's Avatar
I am not looking for anything fancy. I just want to drive the truck. I know how to turn off the stuff I don't need. I recently found out that my ETC (i think of engine temp when I see that) or DBW is not installed as the folder turns red when I plug in the scanner. So my problem is after the tune I just did my idle goes up to 1800 rpm. Don't know why or what I did. With the tune that I originally i got it idled ok, The TPS had to be unplugged and the trannsmission didn't work. Now that I reprogrammed it, TPS is fine along with the tranny just it idles at 1800... I'm dumb *there I said it*
Kevin
File Type: tun
