Need 2002 PCM Pinout for Silverado 6.0l LQ4
Ive found various pinout listings online, but theyre all a little different it seems, Ill have wires where it says none, different colors in a few spots, etc.
Anyone got a diagram for a 2002 HD 2500 Silvy? Service Number on the PCM is 12200411
This is the pin out from the factory manual for 4.8, 5.3 and 6.0
Blue Connector
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
Ground
2
LT GRN
1867
12 Volt Reference
3
PNK/BLK
1746
Fuel Injector 3 Control
4
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/
WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data
15
DK BLU/
WHT
774
UART Serial Data
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL/BLK
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal - Bank 2 Sensor 2 (w/Case Grounded Sensor)
25
TAN
413
HO2S Low Signal - Bank 2 Sensor 2 (w/Isolated Grounded Sensor)
26
TAN
1667
HO2S Low Signal - Bank 2 Sensor 1 (w/Case Grounded Sensor)
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal - Bank 1 Sensor 2 (w/Case Grounded Sensor)
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal - Bank 1 Sensor 1 (w/Case Grounded Sensor)
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch/Cruise Control Release Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRY
48
CPP Switch Signal
36
BLK
1744
Fuel Injector 1 Control
37
YEL/BLK
846
Fuel Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRY
720
Low Reference (w/Isolated Grounded Sensor)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRY
474
5 Volt Reference
46
GRY
416
5 Volt Reference
47
GRY
597
5 Volt Reference
48
GRY
596
5 Volt Reference
49-50
Not Used
51
DK BLU
496
Knock Sensor 1 Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
WHT
1579
Fuel Temperature/Composition Signal (w/L59)
57
ORN
440
58
DK GRN
1049
PCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRY
720
Low Reference (Except w/isolated grounded HO2S)
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal - Bank 2 Sensor 2
66
PPL
1666
HO2S High Signal - Bank 2 Sensor 1
67
Not Used
68
PPL/WHT
1668
HO2S High Signal - Bank 1 Sensor 2
69
PPL/WHT
1665
HO2S High Signal - Bank 1 Sensor 1
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/
WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
Red Connector
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
Ground
2
BRN
418
TCC PWM Solenoid Valve Control
3
TAN
1465
Fuel Pump Relay Control - Secondary
4
Not Used
5
TAN/BLK
464
Delivered Torque Signal
6
RED/BLK
1228
PC Solenoid Valve High Control
7
RED
1676
EGR Valve Supply Voltage
8
LT BLU/WHT
1229
PC Solenoid Valve Low Control
9
DK GRN/
WHT
465
Fuel Pump Relay Control - Primary
10
WHT
121
Engine Speed Signal
11
DK BLU
604
A/C High Pressure Recirculation Switch Signal
12
Not Used
13
LT BLU/BLK
396
Cruise Control Engaged Signal
14
Not Used
15
BRN
25
Charge Indicator Control
16
GRY/BLK
1694
4WD Low Signal
17
DK GRN/
WHT
2523
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
Axle Switch Signal
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22
RED/BLK
1230
AT ISS High Signal
23
DK BLU/
WHT
1231
AT ISS Low Signal
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/
WHT
2124
IC 4 Control
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
Recirculation Door Control
34
DK GRN/
WHT
428
EVAP Canister Purge Solenoid Control
35
Not Used
36
BRN
436
AIR Pump Relay Control
37-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
451
Ground
41
WHT
257
EGR Solenoid Control
42
TAN/BLK
422
TCC Solenoid Valve Control
43
DK GRN/
WHT
459
A/C Compressor Clutch Relay Control
44
Not Used
45
WHT
1310
EVAP Canister Vent Solenoid Control
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
2-3 Shift Solenoid Valve Control
48
LT GRN
1222
1-2 Shift Solenoid Valve Control
49
YEL/BLK
1827
Vehicle Speed Signal
50
DK GRN/
WHT
817
51
YEL/BLK
1227
TFT Sensor Signal
52
GRY
23
Generator Field Duty Cycle Signal
53
Not Used
54
PPL
1589
Fuel Level Sensor Signal - Primary
55
DK GRN
603
A/C Low Pressure Switch Signal
56
Not Used
57
BLK
552
Low Reference
58-59
Not Used
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
GRY
773
Transmission Range Switch Signal C
63
PNK
1224
Transmission Fluid Pressure Switch Signal A
64
DK GRN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-72
Not Used
73
DK BLU
1936
Fuel Level Sensor Signal - Secondary
74
LT GRN/WHT
3213
HO2S Heater High Control (w/Isolated Grounded Sensors)
75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High Control
77
LT GRN/BLK
444
IAC Coil B Low Control
78
LT BLU/BLK
1748
IAC Coil A Low Control
79
LT BLU/WHT
1747
IAC Coil A High Control
80
LT GRN
3212
HO2S Heater Low Reference
