Small HP Tuner issue
Old Oct 15, 2008 | 01:30 AM
Kaneman's Avatar
I know I have been wanting to go that route because you are right I max the MAF in second gear so why have it. I think MAF does its job when I am daily driving it.
Kane
Old Oct 17, 2008 | 08:57 PM
Kaneman's Avatar
Once the MAF maxes out I noticed that the car goes lean and I get some knock. Does that mean my VE table is off a little or do I just need to add a little to the PE table? I have done some WOT runs and I noticed everytime the MAF maxes out it goes lean and a little knock.
I am going to go with a MAP I just want to get everything set for now.
Thanks,
Kane
Old Oct 17, 2008 | 10:59 PM
Frost's Avatar
You need 2 or 3 bar tuning. When the MAF maxes out, the only way to get fuel in is to cheat it in by fudging the PE table in the RPM area that is lean (past maxed MAF RPM).
Old Oct 18, 2008 | 02:06 AM
Kaneman's Avatar
I run about 18psi boost so I would need a 3 bar right?
