Small HP Tuner issue
Old Sep 19, 2008 | 01:13 AM
Kaneman's Avatar
Default Small HP Tuner issue
Ok I am tuning my VE table using the Wideband method from the HP Tuners help area. Everything is working out real well except one small thing and nothing I do seems to change the AFR.
I have one cell 800rpm 35kpa this is where my 900rpm idle falls into. I am running rich and the afr error keeps telling me to subtract more out of this feild but no matter what I put the number at it does not change the afr.
Now here is the funny thing I have my AC idle set to 925 so when I turn the AC on it falls into cell 40kpa and AFR is perfect.
I could raise my idel to 925rpm and the problem may go away but I really want to figure this issue out.
Any ideas?
Thanks,
Kane
Old Sep 19, 2008 | 06:13 AM
2000WS6ICK's Avatar
I may be wrong but your power enrichment eq ratio vs rpm changes how much fuel your getting and will change your afr.
Old Sep 19, 2008 | 09:42 AM
jimmyblue's Avatar
Moderator
Look at the actual injector pulse width and see if
it is the same as the min limit value.
If you use the bidirectional controls to force a
particular AFR, does it follow that or stay "stuck"?
Old Sep 19, 2008 | 10:05 AM
Kaneman's Avatar
That is only when you go into PE and I am just talking idle. PE table is a multiplier that does affect AFR.
Kane
Old Oct 4, 2008 | 02:38 AM
Kaneman's Avatar
Ok I have tried everything, messing with the VE tables a million different ways and changing the injector offset %.
Here is what is in the car:
408 8 3/4 compression
Cam 220 224 581 581 114 lsa
Injectors Racetronix 79lb
I am tuning the car SD OL with my wideband. Once the car is warm AFR is 12.0-12.5 at idle. When the car is cold idle is at 14.7. If I adjust the injector offset I can get the AFR to rise to 17 or 18 and the kpa is at 45 but as soon as I get the car close to 35kpa it goes right to 12.0-12.5. I noticed that my injector pulse does not go any lower then 2.0 no matter what is in the offset too. If the AFR will adjust when it is cold I would think I could lean it out when it is warm?
Just a thought if I raise the timing at idle does that lean it out?
I have tried everything I can think of so if anyone has some ideas please help. I am attaching my basic tune and a scan for that tune. The car runs pretty good except for that damn rich idle.
Thanks,
Kane
Old Oct 4, 2008 | 07:10 AM
Frost's Avatar
your minimum and short pulse tables are still stock...
give this one a quick try and see if it moves in the right direction
Old Oct 4, 2008 | 11:57 AM
Kaneman's Avatar
I will give this a shot today. When are you supposed to change the offset table? I have some people telling me to change this table and then re-adjust the VE table.
Thanks for the help,
Kane
Old Oct 4, 2008 | 01:48 PM
Frost's Avatar
doesn't much matter what is in most of the other tables if the short pulse tables are keeping the minimum pulse width too high by adding back to it...
Old Oct 5, 2008 | 10:56 AM
Frost's Avatar
how was it?
Old Oct 5, 2008 | 02:48 PM
Kaneman's Avatar
I have not had a chance to stick the tune in yet. I will let you know the results as soon as I have a chance to upload it.
Thanks again for the help,
Kane
Old Oct 13, 2008 | 10:34 PM
Kaneman's Avatar
Ok this did mae a difference and at idle the AFR is at 16 or so. Now I tried to adjust the AFR in the VE table but it caused one sell to be crazy high without much change.
As I kept adjusting a few things I can not get this thing to settle at 14.7 it is either 16.x or 12.x. Here are a couple of more log files.
Where is the best place to adjust the settings at?
Thanks for all the help this thing has been driving me crazy.
Kane
Old Oct 14, 2008 | 08:16 AM
Frost's Avatar
your minimum pulse appears to be at a workable level now looking at your logs.
Also, I hope you aren't tuning based off of those logs... You are in OL but you have not reset your LTFT's and they are intermittently swinging up and down based on their previously learned values. The *FIRST* thing to do whenever logging OL is to reset fuel trims in the scanner. This has bitten almost everyone at one point or another. If you have been tuning this way, you will have some fairly decent error built in to your VE.
I bet if you put the car in CL it will find a nice 14.7 idle, which will prove that you can too through VE tuning.
Old Oct 14, 2008 | 10:14 AM
Kaneman's Avatar
Do LTFT still learn even though they are disabled?
Old Oct 14, 2008 | 11:01 AM
Frost's Avatar
No, they are just applied at their previous value in their previous positions.
Old Oct 14, 2008 | 05:05 PM
Sunny's Avatar
Thanks for the useful information.
Do you need to reset the long term fuel trims just before disabling them and MAF?
Old Oct 14, 2008 | 05:45 PM
Frost's Avatar
No, but do it immediately after disabling them and flashing the PCM before you scan for any data that you will make VE changes with. It's in the scanner>Displays>VCM Controls>Fuel&Spark
Old Oct 14, 2008 | 06:36 PM
Kurtomac's Avatar
when you flash a tune...doenst that reset all the trims ie idle trims, fuel trims etc
Old Oct 14, 2008 | 08:05 PM
Frost's Avatar
For HPT, if a write-entire is done it will, not the 20 second write-cal which just updates data...
Old Oct 14, 2008 | 09:59 PM
Kaneman's Avatar
Frost you were totally right once I re-enabled LTFT and enabled closed loop everything fell right into place. I need to do some minor adjustments to the VE table because LTFT's are adding fuel but so far so good.
Should I tune the VE a little more in SD mode and once things are inline re-enable the MAF? I was thinking then do a MAF tune?
I want to thank you a bunch for the help now I am going to put some miles on the car so it can continue learning.
Kane
Old Oct 14, 2008 | 10:36 PM
Frost's Avatar
MAF on a turbo car? I'd move the car over to a 2 or 3 bar MAP sensor and OS. That 40X" engine will max out a MAF by 5psi-ish...
