2002 A4 upshift issues/Want feedback on tune.
I'm new to the tuning world and trying to figure everything out. First thing is the transmission is having upshift problems at WOT. 1-2 feels ok but its 2-3 feels sluggish/slips. Its like the TQ managment is pulling the timing back to let it shift but its not taking place inless I let off the throttle(bounces off rev limiter). Also just dricing at highway sppeds it feels like the TCC is kicking in and out under vary light throttle variations. So I have Incl a scan. The transmission has a Transgo stage 2 shift kit ans a 3500 tci stall. I'm running 3.73 gears with a 315-35-17 tire (25.5in tall)
Second.. The car drives good. Just want someone to look at the tune. See if theres room for improvement. It looks like the LTFT is way off. Car pulls hard! It has a TSP Tq v2 w/dbbl valve springs and stronger pushrods. Also a ported maf. Exaust is stock manifolds w/no cats 4" mufflex exaust.Thats about it.. Its installed in my 92 Z28. All feedback would be appriciated!! Thanks! I'll post the scan data in a bit. I guess it wasn't saved right..
I would suspect the sprag in the TC is done.....sure sounds like it. The all out TCI drag converters are good, but we have seen to many of the 4L60E ones fail with power. You will need to get the valve body in the trans gone through cause there is bound to be metal in it from the TC. Drop your tranny pan and inspect for metal......willing to bet you will see some. Give us a call if you want a bullet proof quickest ET converter for that car. Good Luck!
