BS3 Help
Old Sep 27, 2008 | 01:22 AM
ttcamaro's Avatar
Default BS3 Help
Im setting up a BS3 in my supra. I purchased a BS3 crank trigger. Im going through the directions that came with it. The kit is for an LS1 motor. The cam sync is supose to be a falling edge which is what i need. However when i roll the motor over it always reads 12 volts. Not sure whats up with that. The cams have a tooth ground into them but theres only 2 wires coming out of the sensor. Do the LS1 cars have the same setup 1 tooth but 3 wires coming from the sensor? Wonder if i can just go grab an ls1 sensor. If all the ls1 has is a steal tooth and a meg it should work. Anyone help with that one?
Second the 24 tooth crank trigger im not sure how to set that up. On my camaro with xfi i had to roll the motor 50 degrees before TDC then line the meg up. However theres 24 teeth and i dont know where to start. Anyone help with that?
