Fuel Trim & VE
The I would use the formula's presented above to calculate the VE. When your car is no longer completely stock you can't really test for accuracy as the VE *should* be different. Hopefully after you have done this your l-trims will deviate less from one another - but I still wouldn't use them as a basis for making the change.
chris
It seems that boosted engines can be tuned well enough with the various band-aids provided with Edit, but precise tuning is beyond the capabilities of the stock pcm.
Richard
No no doubt(anymore
) the VE tables do come into play, so GM has to have had some reason for putting them in there - the only thing I can think of is that the MAF isn't responding fast enough to cylinder dynamics, so the tables are a sort of hedge against that - or that it would be to computationally expensive to calculate the VE in realtime (don't know the abilities of the processor), and the VE factor is used as a sort of "charge quality" indicator to better maintain an actual desired a/f ratio.No no doubt(anymore
Thanks ChrisB!
joel
No no doubt(anymore
) the VE tables do come into play, so GM has to have had some reason for putting them in there - the only thing I can think of is that the MAF isn't responding fast enough to cylinder dynamics, so the tables are a sort of hedge against that - or that it would be to computationally expensive to calculate the VE in realtime (don't know the abilities of the processor), and the VE factor is used as a sort of "charge quality" indicator to better maintain an actual desired a/f ratio.I like the idea that we can gather data, attempt to use time and volume to reduce sampling error, and come up with our unique VE, which we can enter into the table and pin the equations with. zI guess the only remaining question i have is; Are the number of RPM divisions in the PE field enough? Not that we really have a choice
chris
Most all intake manifolds should see very very close to barometric presssure at WOT, as do most LS1s, so I could see where just using baro. would suffice.
In the case of the bigger motors (420 ci. +) however, arent some guys experiencing pressure drops at high rpm? In that case would you want to use the pressure ratio of inside the manifold? But being the manifold is technically inefficient at that rpm on a big motor, that would give you inflated numbers correct?
Or would the MAP kpa/101.3 pretty much take care of the loss of presure compared to atmospheric/
The point you are missing I think is that the table works (and is the most noticeable) at part throttle also - and here you have a huge restriction due to the throttle blade itself. Basically when you use manifold pressure as the reference for VE you are measuring puping losses from the pressure sensor to the cylinder - if you use atmospheric as the reference you are measuring pumping losses from the atmosphere to the cylinders.
Re: needing the VE tables - if you use a formula you effectively have an infinitely granular table - you don't have to interpolate for points that are inbetween your lookup points as the formula gives you the exact answer - so the formula based approach in that sense would definitely be superior.
I honestly don't know, but I don't think it's to prevent problems with bad sensors, etc. - the MAF is going to be the primary factor in the VE formulae as well as in stock fueling - if either goes dead then the car is going to run like ****. Now if you have a separate VE lookup table you can reference that if the MAF dies - which is an advantage. I think any harmonics introduced by the continues sensor inputs would be resolved by "tweaking" the model itself. Just add a dampening factor if you need it.
The other question still remains though - what exactly do we need the VE table for - the MAF tells us exactly how much air is inducted - so we now how much air is in each cylinder (the basis for the top of the VE equation) - if you know the mass of the air in the cylinder, your desired fuel ratio, and injector flow rate you know exactly how long to pulse the injector to get that fuel in there.
So what exactly "real world" phenomenon is the VE table compensating/modifying for? Definitely not VE in a classical sense, as the MAF makes that uneccecary. Again, the only thing I can come up with is charge quality - as we are shooting for a perfectly atomized yyy A/F ratio, but due to this being the real world that doesn't always happen.
For this to work though the VE would have to be proportional to charge quality in some sense - well, in a way that required reduced fueling as VE goes down, and increased as VE goes up (as a bpw modifier).
Or it could be some other factor I am totally missing - I am just trying to figure out now the reason for inclusion of the VE factor in MAF based fueling?
The MAF would have a high air flow rate - I dont think the air mass would instantly STOP - but the MAP would be a real large vacuum not close to baro like a high MAF flow situation would indicate. That would cause a fueling erro right/ Maybe the results are averaged, or one takes precidence over the other to cover sudden throttle changes?
Or are my assumptions that it would take some amount o time for the ir mass to lose velocity before the intake manifold pressure drops to vacuum incorrect?
tried making a calculated pid by doing the following
VE = (MAFFlow * (Temp + 273.15) / (Displacement * RPM * MAP) * 212544)* 30
mafflow being the MAF pid in efilive
temp being IAT
displacement .2
rpm being the rpm pid
map being the map pid
when I do this I get values in hundreds of thousands. way off.
what am I misunderstanding here?
thanks!!!
*CLC-00-906
% 0.0 100.0 .2 "{SAE.MAF.gps}*({SAE.ECT.C}+273.15)/(43.25*{SAE.RPM}*{SAE.MAP.kPa})*212544"
TIA
I think I may see the problem. I used ECT instead of IAT and maybe a parentehses issue
What about this corrected using IAT and parenthesis for clarity
*CLC-00-906
% 0.0 100.0 .2 "(({SAE.MAF.gps}*({SAE.IAT.C}+273.15))/(43.25*{SAE.RPM}*{SAE.MAP.kPa}))*212544"
i switched them but still getting the same results?
i wonder if I need to delete the pid and recreate it now that I switched units? hmmmm I will go try that.
Actually I tried to make the formula simpler - the displacement here should be for that of the entire engine.
Try
{SAE.MAF.gps} * (SAE.IAT.C + 273.15) / (347 * {SAE.RPM} * {SAE.MAP.kPa}) * 212544
all you need is that one set of parentheses
Regards
Paul
now that I have all this data what am I doing with it?
am i supposed to build a table with the data to look like edit with map down one side, rpm across the top, and the ve values in the middle then compare this to the table in edit and shift the edit values towards the values I got when datalogging?
In the next release of V6, that will be where you will be able to create parameter MAPs. Meaning, you choose the PIDs for the x and y axes and a parameter to plot in the map and EFILive will show you the recorded values for the selected PID based on the x/y PIDs' values. Exactly the same as the spark and fuel maps in V5 but instead of being limited to spark and fuel they will be fully customisable.
We are working on 3D imaging for the maps so you will be able to see them in wire frame 3D - sort of like a contour map of your parameter.
Paul
