Shutting Off Horn with Car Alarm on 00 WS6
The manual says to press the lock button and the horn will beep the amount of times that its programmed to. Well everytime I locked my 00 WS6 it beeps twice when I lock it. I just want the darn thing to flash the lights with no horn. I know I am not retarded..well maybe somewhat.. but I keep hitting the lock button and trying to hold it down but no matter what it wont change the setting. Anyone know how to? Thanks
You have to be in the programming mode first. from page 2-19 of owners manual:
Entering Programming Mode
To program any feature, your vehicle must be in the
programming mode. Follow these steps:
1. Put your key in the ignition.
2. Turn the ignition to RUN to disarm the content
theft-deterrent/alarm system.
3. Turn the ignition to OFF.
4. Remove the RADIO fuse. This fuse is in the main
fuse block, located on the left side of your
instrument panel. When the main fuse block is open,
the RADIO fuse is located in the lower right corner
side of the fuse panel. See “Fuses and Circuit
Breakers” in the Index.
5. Turn the ignition towards you to ACC.
6. Count the number of chimes you hear. You will hear
one to two chimes depending on the features your
vehicle is equipped with. Refer to the chart
shown previously.
You can now program your choices
shown previously.
