2001 Trans AM simple cruise control Question
Hello guys and thanks for reading.
I have a very simplistic question that I am sure someone can answer very quickly. Last December, I swapped out the auto tranny for a manual and everything went smooth but I missed one connector which I found out shortly afterwards that it was the cruise control. For the life of me, I cannot find where it connects to on the column. The connector itself is a a dual wire with pink and brown wires. It also has a short extension attached to it as well which if I was smart, I would have left that connected where it belonged instead of disconnecting it at the source.
If someone knows about where it connects on the column I would appreciate any guidance that you can provide as I really don't want to drop the column for this one connector. If not to much trouble, a pic of where it connects would be awesome! I miss my cruise so much. Thanks in advance all!
-Blake
-Blake
