resetting the PCM
resetting the PCM
Does anyone know the order/time of fuses I need to pull in order to reset the PCM?
I had a dead O2 and I swapped it out but I need to reset the PCM so I can get the SES light to go off.
Thank you!!
-Kubra
Thank you!!
-Kubra
Unplug your battery. Does the same thing.
I had a dead battery this week since I didn't drive the car for about 2 1/2 weeks and when it got jumped, it took a few turns of the key to get it back in order and now it runs like a champ! One tip: after you reset it, turn the A/C on and it will "re-learn" everything a LOT faster! Otherwise, you'll sit there with your foot on the gas for awhile while the car re-learns everything...
