replacing fuel pump
LS1TECH Sponsor
I just got changing my fuel pump and let me tell you cutting the hole saved me time. The first pump didn't work so I had to remove and return. With out the hole I would've been drop everything back out. I agreen keeping it factory looking, but I don't have cash..I have kids. They cost more that the dealership. I don't have many friends that can give me there weekends. So i borrowed a cut tool (dremel) and one hour later. I had a hole.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Beleave there is a diff between the pump for a steel tank and the plastic tank, do use the hot wire kit, before cutting the hole "loosen" the tank straps a little so the tank hangs down about 1/4 " so/becarefull and do not cut any wires/lines
FUEL PUMP DOOR ALSO
http://www.worldisround.com/articles/12533/index.html
good luck,Johnny
FUEL PUMP DOOR ALSO
good luck,Johnny
