bought a formula
The tires are flipped never noticed I will fix that lol. I've decided I'm putting money into performance stuff right now. So far i have a stall and lt's. About to order my cam. Hope to lower it soon. Thanks for the compliments
Sweet Formula. White is a great color for these cars. Does your car have the powersteering cooler in the uppper radiator hose? If so change over to a trans cooler and an upper radiator hose from the newer 4th gen's. My 99 TA has the coolant and powersteering fluid mixing because of a leak. Maybe also look at getting an oil catch can. I found out these cars have problems with the PCV systems. You could also do an aftermarket trans cooler with a fan instead of using the factory tranny cooler. Just some suggestions. Cool car for sure.
Mine doesn't have the ps cooler. I just had some pcv issues and took the whole setup off and built my own. The trans cooler I'm about to put an aftermarket one on when I put my 3600 stall in. Thanks for the compliments
