Why would rear blinker flash but not the front?
#42
That track on the DRL module fried because there was an electrical short somewhere and the Tail Lamps fuse was apparently too large for the circuit. Double check that fuse value; it should be 20 amps. The light switch is in parallel with that track so you may have some damage there also.
#43
Well all is fixed, after 2 new sockets, bulbs, assemblies, soldering the drl module everything works, Yay for me... and for future reference you don't have to buy the $20+ socket off ebay, I got the same thing from autozone (dorman 85881) for 8 bucks, it says its for 89_96 gm cars but it works great.... Thanks people's that sent input
Now if I can just fix this ******* fuel problem :/
#44
Mine is doing the same damn thing... except it works intermittently and once I flip my headlights on and off again it will work fine again... (sometimes)
It's my driver side front blinker too!
