Cheap mods?
Old Jul 30, 2013 | 12:18 AM
Coyotekiller's Avatar
Default Cheap mods?
I have a 1999 firebird formula what are some quick and cheaper mods for it?
Old Jul 30, 2013 | 12:28 AM
Zlow28's Avatar
nothings cheap
Old Jul 30, 2013 | 01:30 AM
Decadence75's Avatar
A couple of free mods would be to do the coolant bypass on your TB to keep a little heat off the air intake tract.
A good one is to open up the air intake tract more. Here are a couple pics of what I did on mine. It just takes a little time and some patience.
Cut out the area under where the filter sits.
Here is what it will look like installed.
I took it one step further and cut some off the a/c condenser shroud to allow more air to get into the box at once.
As for cheap mods, that is relative. What you consider cheap others might not and vice versa. I would first look into a lid, then a PnP TB -> headers + catback/duals -> ls6 intake. Also get a mail order tune from someone like Frost, TSP, Slowhawk, ect. That alone is worth a good bit over the stock tune. Once you start doing things like heads & cam move on to a dyno tune. But these things will at least get you on the right track to moving fast and enjoying the car.
Old Jul 30, 2013 | 11:46 AM
Thank you it already has xp racing mail order tune and no cats with slp exhaust. Should I go with headers or radials and intake lid?
Old Jul 30, 2013 | 11:49 AM
I would chose headers over tires any day. They will net you sotp and dyno benefits.
Old Aug 2, 2013 | 03:29 PM
toslow5o's Avatar
I would do headers first. You're going to wear out the radials quick and have less $$ to replace the rearend when it grenades from the increased traction (especially if you have a M6).
Old Aug 13, 2013 | 10:06 PM
The_Bird's Avatar
It's worth considering some suspension work. While they aren't adding or freeing up power, they are going to make an F-body feel way better under load. You might want to start with LCAs, panhard bar, a strut bar, LCA relocation kit, and maybe sways.
