Car wont start!!!
Old Jan 31, 2014 | 08:59 PM
ER18X's Avatar
So I can't go out and just buy a new higher amp alternator?
Old Jan 31, 2014 | 09:50 PM
Kevin Lee 487's Avatar
All of the direct fit alts for our cars are 102amp just like the stock AD230 AFAIK so its not as simple as just buying a higher output model.
Old Feb 1, 2014 | 07:59 AM
ER18X's Avatar
Well I had an idea last night or returning the alternator that's on my car now since it's a replacement and having them give me an alternator for a 2003 Tahoe 5.3L 4 pin 145 amp. KG3. I'm hoping they'll say yes if the price is the same if not less.
Old Feb 1, 2014 | 11:44 AM
ER18X's Avatar
Just picked up the new alternator
Old Feb 1, 2014 | 01:52 PM
ER18X's Avatar
New alternator did not fix my problem
Old Feb 2, 2014 | 11:16 AM
ER18X's Avatar
Ok so I've uploaded a video showing a little of what I'm having an issue with on my vehicle. On YouTube I'm ethan101407
Old Feb 2, 2014 | 01:50 PM
ER18X's Avatar
Is it possible for my volts meter to be reading wrong?
Old Feb 2, 2014 | 01:58 PM
ER18X's Avatar
If this helps show y'all.
Old Feb 2, 2014 | 03:06 PM
Paul Bell's Avatar
That's MISTER MODERATOR
The stock alternator produces 105 amps. The voltage regulator is really in the PCM, it tells the alternator when to raise the voltage.
A very common mod is to upgrade to the above mentioned 244 alternator which usually is 145 amps. It will bolt & plug in place of the stock alternator. You would NOT be able to use the original alternator rear bracket.
The car running at almost 13 volts is normal. If the voltage drops a lot with headlights, fans or AC on, and you have a good alternator, I would suspect the battery is bad.
I've had very good luck with Bosch batteries, they're made by Interstate. On sale now at Pep Boys.
Old Feb 2, 2014 | 03:10 PM
Paul Bell's Avatar
Oh yeah, you'll need a slightly longer belt. Good info here:
https://ls1tech.com/forums/cadillac-...r-upgrade.html
Old Feb 2, 2014 | 03:43 PM
ER18X's Avatar
So should I get my PCM flashed?
Old Feb 2, 2014 | 06:03 PM
  #32
Paul Bell's Avatar
Get your car running first.
Old Feb 3, 2014 | 04:40 AM
  #33
ER18X's Avatar
The car runs I drove it for a two or more drive last night and got the same drive today
