7 color halo fog lights help!?
Hey guys, so I have been wanting to put 7 color changing halo lights in the place with my fogs, and I have a fog light out right now so what better time to make this happen? I found a set of new foglights with the halo lights integrated behind the glass of the lights so it would be perfect, but they say they are for trans ams....I have an 02 firebird and they are for 98-02 trans ams, so my question is.. if I buy these, will I need to buy anything else or is this all I will need?
thanks! here is the link
http://www.ebay.com/itm/161032579933
you may need to figure out some small nuts and bolts to attach the universal mounting bracket to the factory bracket, but no aside from time you shouldn't need anything else.
keep in mind to use those halo's you will be forced to use there switch pad which will make the factory fog light switch do nothing. Check out the threads on the Navigator 362 driving lights, aside from a few different minor design differences to the housings it's the same concept.
Thanks for the reply! Ok so if I buy that ebay set of fog lights, I should only have to figure out some bolts and things? I don't need to buy anything else correct? Or did you say I needed to buy the universal bracket aswell?
I got the Navigator NV-362W lights. Don't know how different the eBay ones are but for mine I was able to use stock wiring for the fog lights and needed a separate switch only for the halos.
You will need some custom fab work done to fit the new lights in your old brackets.
