ram air question
I was not much of a believer in the Ram Air. I thought it was more or less a gimmick. But after running out of mod ideas I decided to remove the baffles and seal the air box. In similar weather 1 week apart, before Ram Air mod ave. 1/4 trap was 124.14. After Ram Air mod 125.55 a 1.41 mph gain. I am now a believer.
The vortech kit I was looking at was
http://www.vortechsuperchargers.com/...9-00fbody.html
from what I can gather it dosn't use the factory box, but I could be wrong. If they do use the factory box this could explain why they list greater gains with Ram-Air. 22hp and 13ft/lb difference.
ive seen one installed and it finally connects to the air box. One reason the ram air cars make more power with the vortech is it gets colder air, and a more direct flow.
Originally Posted by *JC*
Amazing?
People will believe almost anything these days... No the Ram Air thing doesn't do a thing except sell cars and look good.
The trouble is is that you won't see any great benefit from Ram Air until well above 100 mph. By the formula above it shows almost 1/5 of a psi of intake pressure at 100 mph. At about 130 mph or so it'll really starts to help. It will do nothing or next to nothing for 1/4 mile times because of the speeds required, unless your trap speeds are very high. I credit at least some of my 172+ mph ORR speeds to the BGRA mod on my car. On a dyno I'm only putting down about 340 rwhp, I'm pretty sure it's more than that at high speeds.
I've got an '00 GAGT, and yes it is unfortunate with the hoods that are out there. I don't really mind people owning the OEM optional hoods that were available in '03, but the TA clones look pretty disgusting. AND, like you mentioned, our ram air is apart of the front bumper anyways. And our ram air isn't true ram air anyways- moreso than the TA. The air goes in, gets deflected by a piece of frame, and then into slits which make two 90 degree bends before hitting the wide airbox, which would kill any pressure that made it that far anyways. With such a fubar'd setup...the CAI does WONDERS for getting our cars to breathe, as well as exhaust.
Anyways...sorry if this is kinda derailing.
The system on the T/A, hood or no (I still swear that the most effect is from the lower openings and that even the flat hood would get the effect, especially with the baffles on the hood, but I digress....) is a very short run that is almost perfectly straight. Just a very slight angle after the filter and right down the TB. That has to be benificial over the old systems mentioned above at any speed.
