2000 Trans Am WS6 - Build/Progress Thread
I had a thread with a few questions about the car, but I figured I'd make a new one on all the information about the car and my progress as I continue.
So here it is:
2000 Trans Am WS6. Currently has just over 8200 miles and still smells like new on the inside. It came with the stock Hurst Short throw and has a 6" stick on it. It has custom Trans Am fuel rail covers and a color matched lid and is otherwise stock.
The car has the original tires and wiper blades and has been literally untouched it's whole life. I am the 4th owner and plan to keep it how it is and maintain the cleanliness of the vehicle. It also came with the original window sticker and build sheet, that I will be making copies of and framing for shows.
The only plans I have are a Wheelskins steering wheel cover, shift ****, floor mats (all to preserve the original pieces) and possibly Corsa Clone exhaust tips.
Enough of my talking, here's the car (those are bugs on the front bumper not rock chips ):
Cell phone pics
My current daily that will be helping to keep the miles off the bird
I apologize for the low quality uploads, I'll upload to flickr and re-upload when I get home from work.
Until then, enjoy
So here it is:
Cell phone pics
Until then, enjoy
I want to drive it like it was meant to be driven and keep it clean so that others can enjoy it as well.
It's plenty quick and plenty fun, so mods aren't high on my list right now.
Also, oil changes were recorded throughout the cars whole life so it looks as if it has been treated really well and that helps to confirm the mileage. Although I know that can be faked easily, the condition of this car in person is fairly impressive.
Just yesterday I realized that my engine bay, with 45k miles, is adorned with multiple nicks and scratches from wrenches. And I sat back and realized that I'm not that mad about it. I bought the car bone stock with 34k miles and everything to it was done by me; both good and bad, and they were all learning experiences since this is my first car I've modified and I've done it all myself.
As a side note, I would like to prevent the door panels from cracking but don't really want to take them off. Does anyone know if putting a dab of epoxy on the starting point of the crack (there's already tiny cracks) will help to prevent the cracking?
I already always keep the windows all the way up and keep mine and other's arms off the door panels as much as possible. It also stays out of the sun for extended periods of time.
Another question I have is whether or not there is a difference between 98-00 and 01-02 master cylinders?
You can see in this pic as well that the passenger side of the hood was a bit low, got that fixed yesterday, nothing major, the bumper under the hood was just a bit low, so now she looks proper (not in this pic)
Great looking WS6! That is definitely one to keep relatively stock, even if you just weekend cruise it and keep it for years the mileage should stay pretty low and make it a decent investment.
Honestly, it's stupid easy to take the door panels off and put them back on. I can have a door panel off in less than five minutes, haha! Just take them off and fix it correctly before the cracks even start. You'll be so much more happy that you went the extra mile to do it correctly, and with your car in the shape that it is in I would make the effort!
I took my panels off, removed the trouble-causing stables, then sanded down the area around the crack, laid down plastic mesh, then JB-Welded the area, and re-stapled. They stopped cracking but they were already cracked; my car is mainly parked in a garage now but I'm not sure the original owner did the same.
I'm the same way in my Monte Carlo, just pull them out and be done with it. Like I said above though, I really worry about cracking them when I pull them off.
Is it pretty much just remove the staples and be done with it? Or do you have to put something else in, in place of the staples? I've seen the threads, just a little curious yet.
I see the fix thread and it looks straight forward. I just want to see how to pull the panel before I do it.
I assume you just pull the staples closest to the crack spot and replace them with something smaller (to hold the trim down and allow some movement) followed by a little epoxy on the back?
Do you know where I can find a good removal thread?
Otherwise, you just need to remove all screws in the panel, then take the panel up (it hooks near the window) and then slide it forward, pulling it through the door handle. Then disconnect speaker cables and the little light bulb on the door handle.
I'm pretty sure I followed a HOW-TO on replacing the window motors (thread possibly or LS1howto.com).
Any ideas as to what to use instead of staples this time around? I've seen anything from zip ties to wire.
