Thermostat question
Old Oct 16, 2014 | 07:54 PM
Stan1911's Avatar
Default Thermostat question
Sorry newbie question....
I will be doing a cooling system flush this weekend on the 2002 Firebird, 3.8ltr, and was thinking on removing the thermostat and replacing it with a new one at the same time.
But looking at it, right behind the housing is a steel/pipe/line (not sure what it is) that is so close it looks like it would have to be removed also.......not sure I want to start dissembling things with out knowing what they are.
So my question is, can the thermostat be removed with out removing.....what ever it is directly behind it?
Thanks for any replies.
Old Oct 16, 2014 | 08:23 PM
M4N14C's Avatar
Power steering cooler? We'll need some pics though.
Old Oct 16, 2014 | 09:36 PM
Stan1911's Avatar
Here is a pic borrowed from Google. It is the corrugated metallic looking pipe across the top of the thermostat housing?
Mine is almost tight, not sure I can get the stat out or not.
Old Oct 18, 2014 | 08:27 AM
Stan1911's Avatar
No ideas?
Old Oct 18, 2014 | 08:43 AM
bgw70's Avatar
Veteran: Air Force
That is the EGR valve Pipe. It should be removed when you are replacing the thermostat.
Old Oct 18, 2014 | 09:48 AM
Stan1911's Avatar
Got it (exhaust gas recirculation)
Thank you!
