ignition cylinder swap?
finally got the engine into the doner body from my old 98 T/A nearly 100% complete excluding paint. Not bad for a kid. now my issue, other than vacuum linesDX my new 98 T/A body didnt come with the ignition key. soooooo i would absolutely hate to buy a replacement key for 150$ or whatever. my question is, can i take the old T/A's ignition cylinder and swap it into the new T/A with the fitting key? anything to save a couple hundred. please let me know if this tedious task can be accomplished. Took me 2+ months to build rebuild this freaking car from nearly a shell, only thing in my way is a key
The last time I had GM cut me a new key it was $25. To answer your question, yes you can use the old ignition cylinder. However, you'll either need to do the VATS bypass or have a new key cut to match the value in the current car's BCM.
Unless you're lucky and the two BCM's have the same pellet value stored (1 in 15 chance). Easiest solution, go get a new key from GM.
it took me about an hour but, I just remembered I am using my older PCM and wiring harness, so i went with the swap. the old harness/pcm had the vats bypass on it already. so i should be in the green. but i do need a new key for the door locks, no big deal
