Spark plug replacement on '94 Trans Am.
I have a '94 Trans Am GT. I went to change plugs and ran into trouble with the no. 2 cylinder (passenger side front plug). This side has the generator, power steering and a/c compressor all on the r/h side of the engine. It also has several steel tubes restricting access to the plug. I have had a couple of friends also try to get to the plug without success. I also dropped the y pipe and removed the starter and still could not reach the plug due to the motor mount. I could really use some advice from someone who has actually been able to get this plug replaced. How did you do it?
