LS1 Trans Am Engine Ticking During Warm Up
Not sure, some slap louder, some longer, some barely at all..as long as the noise is consistently going away, and not getting louder under load, i would not worry at all
a lifter tick would always quietly be there and a bent pushrod would get louder and faster under acceleration
Yes, the ticking always starts at 2-2.5 min then it ends at 7 min.
https://ls1tech.com/forums/general-m...-your-car.html
i personally would seafoam an ls1 every 15-20k
Save the manuals!
That seafoam thread is so long that there are a few terds mixed in with the nuggets...
In the '90's, GM came out with a TSB that warned against frequent carbon cleaning. If I recall correctly, the logic was that some carbon deposits beneficially help seal up marginal gaskets that would otherwise leak and that carbon cleaning on high mileage engines could lead to leaking gaskets. So, the recommendation from GM was to only clean cars with related performance or mileage problems.
Doing a fuel system treatment every 10K miles is probably a good idea. Dumping a can of seafoam in the tank would count for that and should be fine. However; I would hesitate to do the full aggressive foaming treatment of the top end, etc. unless performance of the car is dropping off. Always putting TopTier gas in the car is also a great thing go do: http://www.toptiergas.com/
Save the manuals!
The one thing we are really short on technically is quantifiable information on how quickly carbon builds up. There are lots of variables there and the test is to tear apart the engine = not fun.
I think the high mileage caution regarding carbon cleaning is a good one, which is the main caveat I wanted to put on the table. As well, it's probably more of a concern these days, 10 years after the original Seafoam thread started.
There are a lot of Seafoam fanboys/girls who will promote the product and swear that there's 100% goodness in the can, which I understand GM's engineers do not believe is the case. Given that fact, I would be reluctant to recommend that doing the treatment every 20K miles is a good thing without evidence that it's truly needed.
^ That being said, I understand that many new DI engines do have a rapid carbon build-up problem, but that should not apply to the LS engines run on good gas.
my apologies i havent read that seafoam thread since it was ~30 pages long. here is the proper way to clean your top end as seafoaming thru the brake booster line has been deemed a joke
you raise good points on no concrete knowledge of carbon buildup. these are just my opinions. I haven't seafoamed a car since 2008. op do your own research on the subject to decide if this is a route you'd like to try. my friend (lt1) had decent results with seafoaming twice (40k and 75k) and will be trying mccc this week, now 40k pampered miles later
Save the manuals!
lol I hadn't even seen that one.
We have a lot of really good/long threads that have developed "tribal knowledge" that should probably be cleaned up and consolidated to be useful stickies. The seafoam one would be difficult to do that with, I think.
We could definitely use a good write up on piston slap, though! This ticking comes up a lot and I don't think we have a good tutorial. (The link I posted above is... probably not "it.")
