Just swapped led into front bulbs
It was easy. Got amazon bulbs. I can list.
parking lights have 2 flaps in front of wheels with 2 10mm bolts each side. Drop flap and change bulbs.
use new heavy duty flasher under steering wheel panel. 2 Phillips and 2 7mm bolts. Drop and swap flasher located on upper right side of wheel
fogs I changed from top. I pulled harness first then twist and remove bulb. Repeat for install
quality of bulbs was night and day
See passenger fog bulb is original color
Yes just a plug and play
flasher
<non-sponsor link deleted>
front turn/park switch color white/orange
Fog lights
rear lamp turn brake & reverse
flasher
Fog lights
Last edited by wssix99; 12-11-2016 at 03:35 PM. Reason: non-sponsor links removed. please use manufacturer links instead of non-sponsor sales links to illustrate parts.
