Fog Light Bulb Replacement
A word of caution when replacing your fog light bulbs with anything other than spec.
Instead of 880 27 watts, I used 893 37 watts. They were listed as a suitable replacement, and were a little brighter, which I liked. I didn’t think 10 watts would be a big deal.
Less than a year later, you can see that they melted my housings.
I was wondering why one light was dimmer than the other. This is why.
Is this because of the gasket? When I first went to pull the bulb, the gasket had turned to a gum like consistency. Or maybe not. I think it came from the plug, not the bulb...
I was surprised to find the housings and lenses were plastic. I though they were metal and glass, but that would make too much sense.
New housings are ordered.
Considering going to LED. Is there a simple plug & play bulb that I should consider?
I’m not looking for blinding white. I’m not looking for a mod.
I just want to minimize the heat while trying to look close to factory whiteness.
Thanks in advance
Thanks in advance
Save the manuals!
You'll need to use a 880 to manage heat. If you want more brightness, you can go with a halogen or xenon bulb. For color, you can pick out any color temperature you want. (You have lots of choices online.)
Save the manuals!
This is probably a situation where the OP should self-educate on all the options out there before shopping. If they call a store, they are going to get sold what the store has in stock vs. what they may really want.
1 Post
When I did the LMC headlight housing mod, I went with Putco Pure Halogen bulbs in both the headlights and fogs. Went with the 4000k bulbs and haven't had any problems. Think they were called nitro blue back then, but have since changed to mirror white, but still 4000k. Not necessarily brighter, but I feel they have a whiter light. Bulbs are stock wattage too.
Save the manuals!
1 Post
It has probably been 3 or 4 years since I did the mod. My wifey is cool and likes driving the T/A with the fogs on all the time, so they have been used and are still working. I have used Putco brand in other cars and have had no complaints.
