Location of horns on last generation Firebird
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
While changing out a bad headlight on the passenger's side of the car, I found the location of the two horns. To access the horns turn on your headlights and then rotate the **** back so only the parking lights are on to keep the headlight doors open, then remove the black plastic bezel that surrounds the pair of headlights on the passenger side. The two horns are mounted to a brass colored bracket right there. The horns are black and their "trumpets" are pointed downward to keep water out. The second picture below is the same area but I moved the camera closer; we can see one of the horns in the middle of the picture.
![](http://home.comcast.net/~David96SS/WS6/horns-far.jpg)
![](http://home.comcast.net/~David96SS/WS6/horns-near.jpg)
It looks like there is room in there to mount air horns and such. I hope this helps.
