Trans Am headlight stuck down
My drivers side headlight would randomly not want to raise up a while back. It seemed like the metal arms that extend the headlight up would almost get jammed up. My current issue is worse, I literally cannot even manually turn the headlight motor to raise the headlight. Its very tough to spin the little turn dial on top of the headlight motor itself, and it just keeps spinning without lifting the headlight. My motor never showed signs of wear or grinding noises up to this point so I'm a bit confused. Something seems like its on a bind and I've tried lubricating all of the pivoting points on the headlight assembly with no luck.
The motors on the worm gears also become loose over time and the mis-alignment causes wear or even disengagement. You'll have to take the entire motor assembly out to fix it with a new gear (brass or aluminum) or to fix the motor tangs that hold it on.
Go to 16:20 minutes in my video and you can see how the motors are loose on the housing.
That helps a lot I'll have to check for that issue. The only problem is, how do I get the motor out if the headlight won't come up? Every video I've seen they manually raise the headlight up so they can access the bolts that hold the motor in.
Maybe you'll have to try turning the motor by hand and lifting a little. Take off the rubber booty, then use allen to turn the motor, or by your fingers. Left is up, right is down. The plastic trim frame has 3 screws but you need to have the headlight up almost all the way to get to them. The body colored cover has 4 screws. The frame below that has 4 also IIRC, but you dont need to take any of that off it you can raise the light by hand just to get to the motor. Removing at least the trim piece gives you some room in the front.
Save the manuals!
Disconnect the bulbs and then remove the nuts on the two hinge bolts on either side of the headlight assembly. The whole assembly will then rotate up on the actuating arm and you'll be able to access the bolts holding the motor in. (At that point you can also take off the bolt holding the actuating arm on, so you can place the headlight assembly aside and work on the motor in the clear.)
So I got everything apart. Opened up the motor and somehow moisture must’ve been getting inside and rusted out all of the components. I think it’s seized up from rust. I went ahead and ordered a new cardone unit to replace it because I’m not sure this is salvageable.
So I think the reason for the corrosion is because my car didn't have the protective rubber boot on the top of the headlight motors. I can't seem to find a part number or anyone who sells them. Anyone have a part number?
Save the manuals!
The motor picture you posted isn't stock. It's a replacement, so there could be a number of stories there. (The stock motors didn't have screws holding on the gear cover. The stock gear cases were sealed.) ^ So, that's probably when your motor boot disappeared.
We haven't seen anyone carry the rubber boot. Assuming it will fit the aftermarket motors, you would probably need to search the salvage yards for them.
