Need help on rear taillights on 02 trans am
Finishing up total rebuild of my car. Combined and relocated fuse boxes, cut down harness and tucked. replacing all brake , turn signal and parking lights over to morimoto LEDs. Front and rear........in rear, Do both brake/taillight bulbs flash on each side for turn signals? I was sent 4 morimoto load resistors with the order and I'm assuming 1 is for each side in parking / turn in the front bumper. That leaves 2 for the back...not sure how to wire them in
Ungrounded Moderator
Firebird taillights have three bulbs on each side. The outboard one is a single filament used for parking/running lights only. The two inboard ones on each side both function as parking/running lights (dim filament) as well as brake/turn signal (bright filament). To properly install load resistors you would need two on each side (they connect between the yellow and black wires on the left side, dark green and black wires on the right side). However, an easier solution is to install a No-Load LED flasher under the dash and eliminate the need for load resistors altogether.
John
