Some questions...
I recently bought an 84' Pontiac Firebird (with the V8). There were a few problems with it when I bought it. It has a tilt steering wheel which is non-functional (I can move it up and down at my own free will
) But I can still drive it. Also the high beam switch and washer fluid switch is not working as well.
Lastly, when I turn corners at slow speeds the car tends to make a low grinding sound. (And I don't feel it from the steering wheel)
I figure most of you guys would know a lot more than me at firebirds and
I would highly appreciate some information into what I should do about
these problems.
I'll be waiting for a response
.Thanks!
-AlbertVII
problem 3: Check fluid in p/s setup. Also inspect wheel bearings for wear.
My cars 20yrs old, engine is 10yrs old, tranny is 7yrs old, and I still paid about $25k less than ^^
As far as the grinding noise....check the brakes front and rear and check the rear end. hard to determine on the net without seeing or hearing the car. Good luck!
Mike
