Pontiac 455 with #48 heads.
I was wondering if anyone has a Pontiac 455 with pontiac 48 heads on the engine.
I am planning on putting #48 heads on my 1974 455 engine but I would like to know what size dish pistons should I use, what cam, etc. I also would want the engine to run on pump gas.
thanks.
thanks.
http://www.transamcountry.com/forum/
theres a link to a great group of guys the can answer anything about trans am's etc
Ditto. Find yourself some 1971 400 #96 heads. Will give you a perfect 9.2:1 compression on a 455. Also, check out the following link:
http://forums.performanceyears.com/forums/
Great information and lots of tech discussions.
http://forums.performanceyears.com/forums/index.php
good luck with the build
whats the Poncho going in?
