Window motor problems!!
I got into the car this morning , driver side window went down an inch and stoped, it was running great before, after playing with it I can jog the switch and noticed that when the window goes down it slows downs ALOT clicks then keeps going down, or stops before it clicks and I have to jog the swtich updownupdownupdown, going up is a different story it goes up fine no clicks or nothing , car has 32k miles should i do the motor replacement or do I need to replace the entire assembly spring and all?? oh and its an 2000 Trans am
The motor has an internal circuit breaker that weekens.
Here is the FAQ for window motor replacement:
https://ls1tech.com/forums/showpost....1&postcount=18
