Headlights stuck again.......
Both my damn headlights are stuck up again, after I got it back from the shop. Also I have some water in the bright headlight pass side. Do I have to have the dealer do it for me? Or is it simple to order the parts and do it? Thanks.
'Bird Director
You might check the fuses. I blew a fuse once while swapping out a bulb somewhere on my car (can't remember which one). My headlights were stuck up, and the blown fuse was the cause. I remember it was one of the 20 amp fuses in the end of the dashboard.
As far as moisture in your high beam, that's as easy as buying a new headlight. Us 'bird owners still have the "old style" bulbs where the whole thing gets tossed when it goes bad. If you do end up replacing one high beam, I'd go ahead and replace the other one too. Otherwise, you'll probably have one that is much brighter than the other. That's only if it bothers you. I rarely use my high beams, so it probably wouldn't bother me as much unless it was the low beams. I did have that happen to me, and I couldn't handle one low beam being brighter than the other
