headlights go up and down when I lock/unlock using the key fob?
Weird
I have never had that happen. Is there a feature I need to turn off? something mixed up? Can't figure it out
Has anyone had this problem or know what I am talking about?
Thanks in advance.
Bob S.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Thanks in advance.
Bob S.
I just went out in the garage and double checked. When I lock I get the double horn, all the lights come on and the headlights come up and down, but do not turn on. When I unlock I get everything the same except the horn.
hmmm anyone?
Bob S.
hmmm anyone?
Bob S.
Mine used to do that... Half of my headlight gear was stripped out so I did the whole headlight procedure where you manually turn the motor halfway so it uses the other half of the gear and when I bolted everything back together it stopped doing it. I dont know if it will do the same for yours but that seemed to be the problem with mine.
![Stupid](https://ls1tech.com/forums/images/smilies2/stupid.gif)
He's right mine did the same thing.
lol..i think its in the connector. the fact that they stop doin it when you do the motor gears is just coincedence cause you have to disconnect the connector to do it. i would check the plugs for corrosion, but if you've had issues with your gears grinding in the motors than you'll wanna do them anyway. hope this helps..good luck.
Mine started doing it on my 96' WS-6, it started when the motor's were taking a ****, I ******* hated it, 'cause everytime they went up, the gears were grinding and it was loud and obnoxious. Make a long story short, I changed the motors and it stopped popping up when I used the fob. Good Luck.
Originally Posted by phantomzer0
its not the motor its just the gear, you can get a new gear from bfrankers site for 40$ made of machined metal....
Originally Posted by TARZAN
Mine do it also....But they also make that nasty "errrrrruuuuuhhnnnn" noise when the driver side headlight goes down, because I need to move the gear lol...
-Will
-Will
that's exactly the sound it makes....just a little bit longer
it's embarassing...If i go anywhere, i make sure to turn the lights off while i'm still moving so that my exhaust overpowers that terrible sound...
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
It is the change of resistance affecting the limit switch on the motor. The teeth on the gear are ground down the motor keeps turning even after the door is down, until it reaches enough resistance to turn the motor off. My terminals didn't have any signs of corrosion when I had the issues with my bird. I did look at the connection system since I design the inspection tools for the components.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
