Everything about my formula.
Isnt there a website were if you type in your vin# it tells you evetyhitng about your car even the production number? id love to know what number built my 01 formy is seein how only 1037 were built.
'Bird Director
It doesn't break down into specific models, but you can see your GM production number by using your VIN. The last six digits of your VIN is your production number. GM started numbering with 100,001. Mine shows 101,171, so it was the 1,171st one assembled for the 2000 model year. Now the debate is how they handled the number....were the Camaro & Firebird combined? Were they numbered seperately?
There is no production number for regular Formula-Trans Am-Z28 f-bodies. They were only given production numbers at SLP (for the SS) or ASC (for the WS6).
If you want to know everything about your car, check the RPO sticker on the driver's side door. Here is a list I have of my options- you'll probably have a lot of the same.
AAA - STANDARD EQUIPMENT PROCESSING OPTION
AK5 - DUAL FRONTAL AIR BAGS
AR9 - SEAT, RECLINING BUCKET W/CLOTH
AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS
BBS - HURST SHIFTER
C60 - AIR CONDITIONING, CUSTOM
DG7 - DUAL REMOTE CONTROL MIRRORS
DL5 - DECAL ROADSIDE SERVICE
FE2 - SUSPENSION SYSTEM, HANDLING
FE9 - FEDERAL EMISSIONS
GU6 - 3.42 RATIO REAR AXLE
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
IPB - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR
LS1 - 5.7 LITER SFI V8 ENGINE
MM6 - TRANSMISSION, 6-SPEED MANUAL
MN6 - TRANSMISSION, 6-SPEED MANUAL
NF2 - FEDERAL EMISSIONS - TIER 1
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT ****
NW9 - TRACTION CONTROL, ELECTRONIC
PA6 - PAINTED STYLED WHEEL
QLC - TIRES, P245/50ZR16 PERFORMANCE
R9P - POWER PACKAGE INCLUDES: POWER DOOR LOCKS RETAINED ACCESSORY POWER, POWER WINDOWS INCLUDING EXPRESS DOWN DRIVER'S SIDE DUAL POWER SPORT MIRRORS POWER ANTENNA STE - ASM PLT ST. THERESE
T78 - HEADLAMP CONTROL DELETE
UB3 - RALLY GAGES W/TACHOMETER
UK3 - STEERING WHEEL RADIO CONTROLS W/LEATHER APPOINTMENT GROUP
U75 - POWER ANTENNA
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
V73 - VEHICLE CERTIFICATION U.S.
WS9 - FORMULA OPTION
W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
W66 - FORMULA OPTION
1SA - OPTION GROUP - 1SA
28U - PAINT, NAVY BLUE METALLIC
52B - TRIM, TAUPE CLOTH
52I - TRIM, TAUPE
6ZL - COMPONENT FRT LH COMPUT SEL SUS
7ZL - COMPONENT FRT RH COMPUT SEL SUS
8TH - COMPONENT RR LH COMPUT SEL SUSP
9TH - COMPONENT RR RH COMPUT SEL SUSP
A31 - POWER WINDOWS
BBS - HURST SHIFTER
U75 - POWER ANTENNA
52I - TRIM, TAUPE
