One more time ...Bandit T/A w/LS1 Conversion
#62
Originally Posted by y2k_ta
That's a great look!
http://store.finalstageauto.net/workvsxx.html
Unfortunately, as I suspected, they're about the same price as the Fikse's - roughly $780 a piece. Too pricey for me right now. Maybe some day ...
#63
'Bird Director
Originally Posted by nautiboy
Definitely agree with you there! I finally found out what those wheels are: 3 piece Work VS-XX 9" x 18" front and 10" x 18" rear:
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm not much of a fan of large wheels, but those just look right on that car. Especially with the overall stance of the car. It's too bad they're so expensive
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#64
Yeah, yeah. I've been beaten into submission on that one. I'm in the process of trying to figure out what I want to do. Purely on style, the Fikse FM/10's with gold anodized centers look the best to me, but the price is really steep (about $3K for a set). Then there's these:
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
#65
When you do a conversion, you are held to the emissions standards of the engine you're putting in (and the engine has to be newer than the body). So I need to comply with full OBD-II emissions. That's going to be a big PITA, but it's possible.
I'm still doing a 2.5" true-dual exhaust exiting at the rear-quarter with the dual-tips just like the original. Everything after the cats is free-game (though you're still subject to noise pollution laws) so that's not an issue. I haven't decided yet on which muffler to go with. The Sweet Thunders sound pretty nice.
After it gets passed by the smog referee I'll look into additional mods. The refs are extremely strict so it's easiest to go through as bone-stock as possible.
Almost certainly high-flow cats, possibly QTP LT's, CAI, maybe a pulley, maybe a ported TB and a dyno tune. The rest depends on how much the conversion ends up costing me and how much I decide to put into suspension and brakes, and whether or not you dweebs talk me into changing out the wheels (that money could be put into a nice h/c combo ....).![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
One little thing about cheating the smog guy's I picked up. If you add about a 25% mixture of methanol (called M85 at the green gas stations) you will get pretty much any car to pass smog.
I had a friend when I was stationed in Colorado that had an oooold datsun that he couldn't get to pass. He threw 2 gallons of M85 into his tank with 6 gallons of premium go-go juice and that puppy blew cleaner than the pope's last breathalyzer test. And to top it off, he had punched out his catalytic converter about 6 months prior to this. M85 acts as an oxidizer during the combustion process significantly raising the O2 level during the combustion, resulting in almost NO emissions at all. The smog tester ran the test twice to make sure he had the correct results.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#66
Amazing car! I used to have a '78 black and gold very similar to yours. I think the car would look best with stock deep dish gold snowflakes, it would look ALOT classier and would be much less expensive than Fikse's...just my opinion. After all you spent all that time and energy restoring the car to an extremly clean stock look, might as well go all the way with stock wheels too. I wish I would have kept mine and put the LS1 T56 combo on it. Good choice and good luck with your wheel decision.
#67
Originally Posted by mcG
those wheels on that car look awesome
#68
I had a friend when I was stationed in Colorado that had an oooold datsun that he couldn't get to pass. He threw 2 gallons of M85 into his tank with 6 gallons of premium go-go juice and that puppy blew cleaner than the pope's last breathalyzer test. And to top it off, he had punched out his catalytic converter about 6 months prior to this. M85 acts as an oxidizer during the combustion process significantly raising the O2 level during the combustion, resulting in almost NO emissions at all. The smog tester ran the test twice to make sure he had the correct results.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#69
Originally Posted by nasty99WS6
If you like that look, why not try some rims off of a late 80's early 90's GTA with the gold centers? Probably alot cheaper, if you could find some that is, and might not look bad. just a thought.
Soooo... I'm the proud new owner of a set of Works VS-XX's. Unfortunately since they're custom-made in Japan, it's going to be 60-90 days before I get them.
#70
#71
By the way, in case anyone's curious ... the current status of the project is that the engine and transmission have been pulled. The chassis was a little uglier than I was expecting after a frame-off restoration (grr...) so now I need to figure out what to do about cleaning it up.
And, I'm also now looking at replacing pretty much all of the steering and suspension. My build plan is looking like:
SC&C stage 1 kit
- adjustable, tubular upper control arm with greasable race bushings
- tall lower ball joint for better geometry
pro-touringf-body:
- front&rear springs
- solid body bushings
- subframe connectors
- rear sway bar drop link
Moog:
- inner/outer tie rods
- center link
- upper ball joints
- pitman arm (maybe - I still haven't found it yet)
Global West:
- del-a-lum bushings for lower control arm
- tie-rod sleeves
Energy Suspension:
- poly bushings for front&rear sway bar
Edit: Forgot to mention QA1 adjustable shocks front&rear.
I'm probably replacing my steering box too. Right now I'm debating between the AGR, DSE and ATS boxes. All are about 12:1 ratio.
And new disc brake kits for front&rear from Precision Brakes.
My goal is to have a car that looks like a nice, stock restoration but is a helluva performer.
SC&C stage 1 kit
pro-touringf-body:
Moog:
- center link
- upper ball joints
Global West:
- tie-rod sleeves
Energy Suspension:
#72
very nice. if it wasn't for commiefornia smog, i was goin to say, do a victor jr. intake with a 90mm TB on top and keep it injected. no way for a MAF that way though. im thinkin about attempting to do a 70 T/A clone with LSX power and go that route. you might be able to make a bracket that bolts to the fuel rails, or fuel rail brackets, that could hold the shaker to the engine.
#75
Originally Posted by HPP
Cool conversion. Any ideas about the final weight and balance?
Unfortunately I didn't weigh it before I yanked the engine. The original specs say that it should weigh 3600lb. The only person I've talked to so far that has weighed his weighed in at 3800lb, but that was after putting in a larger motor. So I think 3600 is probably about right.
Best estimate from those that have done the LS1 conversion is that I should drop about 300lb compared to my old poncho 400. Then I'm ripping out a/c which is pretty close to 100lb (!!). I'm not entirely sure how much more I'm going to drop with all of the suspension/brake changes, but my guess is I might lose as much as 100lb more. So I might lose as much as 500lb.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
That would bring the weight down to somewhere between 3100 and 3300lb.
With the lighter engine and ditched a/c, the weight is going to move back. Plus the mounts from ATS move the engine as far back and down as you can, which is good there.
The CG is going to drop a bit too, and I'm starting to worry it's going to drop too much (e.g., I'm going to be too low). It seems every choice I make drops the car even more, even though that's not exactly my intention.
So it really ought to be in pretty good shape to be a solid performer. Whether or not I'll be able to clear speed bumps is another question.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#77
Here's a question- I had a 78 in High School (Alabama), and it had 400 Pontiac (Not the 403 Olds) in it. It was fully built by Gary Anders, and would haul a$$. Anyway, what made you decide on an LS-1? With the availability of parts for the 400 Pontiac, or building a 455, why did you decide to go LS-1??
#78
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by 30thanniv
![Gruffy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_gruffy.gif)
I think we all here realize that the only "bandit" ta was made in Cherry Hill, NJ by an aftermarket company.
As far as the car posted above, ******* bad ***.
#80
Originally Posted by Black FormulaLs1
go w/ the gold TT2's 315/s out back ..that car is so damn sexxy if i wasnt married...anothe rthought is that you could do a carb set up or go to edelbrockintakes.com and check out that intake..maby ou coudl USE that pretty shaker?
