Next mods?
BTW, you are correct, the ORY won't really do too much without the headers in front of it. Good luck with whatever you decide.
Definately get an underdrive pulley. ($225 with belts = 9 rwhp)
Then install some good headers ($500 coated Pacesetters with y-pipe = 25hp)
Then get car tuned on a dyno. ($300-$500 = 25rwhp)
That's what I would do... ~Joshua
__________________________________________________ ______________________
1.) LT's, highflow cat and Y-pipe
2.) Dry NO2 system from TX
3.) 3400 - 3600 stall converter from ????? (maybe Vig)
4.) 3.73 gears w/ posi unit
Unless you have a big cam, or it's a weekend toy that has the pedal down most of the time I'd consider getting a covertor that's slightly smaller.
I would advise doing the headers, smaller coverter (2,800~ 3,200max), gears, cam/springs, nitrous in that order if I had an auto. ~Joshua
So ur say'n that I should go with headers and then a smaller stall then I had in mind?
It wouldn't get out of it's own way unless you pushed the pedal all the way down and fine-a-f#ck-inly the car would move out.
I'd do headers, a 2,800 stall, and think about what cam specs would be good for your tastes. The 2,800 stall is a good all around stall speed.
Sell that ring and put 6k into a Procharger (reliable,complete supercharger kit) and you'll never sell that WS6.
Exotic Performance Plus (a sponsor)===>
They are straight up guys and they have the absolute best prices. THe handheld tuner comers with the P1sc kit.
