Free MODS for ls1's
#41
I know this isn't a stock free mod, but it is a modded free mod. Anyone with an aftermarket or ported/bump stop modded throttle body should make sure he/she is getting full throttle. I was at 90% when I checked mine. I removed the floor mat and bent the throttle cable mount to get to 100%.
#44
Originally Posted by t/a for life
can someone exsplain or post a link that shows where these baffles are so i can cut them out...thxs
pop your hood, take your lid off, take the filter out of the housing. you will see a tray where the filter sits in take that out. from there you will see a bunch of plastic that covers that bottom of the air box an radiator. see that?? ok now there are 4 body pins and 3 or 4 bolts that will need to be removed.once you have the bolts and body pins off you can cut all that plastic out. it is very easy takes like 30 mins from start to finish. let me know if you need more help
