traction control switch mod
I bought the SLP reverse
After about 2 weeks of remembering to turn the TCS off every time I got in the car I bought the $70 reverse switch. Default mode is off unless you hit the switch, takes 2 minutes to install. It rains like hell here in NW Oregon and I do use the TCS sometimes. But I decide when and you don't want to be sitting at a stop sign and forget that you have TCS on. You may get embarrassed. But the dash warning light stays on, which is kind of annoying.
Originally Posted by Honda Hunter
Correct me if I'm wrong but if you pull the fuse for TCS wont you also lose ABS?
It's fine to pull the fuse, but if you put it back in or use a switch like 01badbird you have to turn the engine off and back on for it to start working again.
I pulled my fuse a long time ago and as long as I buy good tires I never have needed to put it back in. I keep it close by just in case.
#33
Mine does not have the Traction Control box under the A/C control Panels, Did some of the 2001 WS6 not come with the TCS or is it something the previous owner did to the car. I don't understand why it would not have it. I really need it, traffic is crazy in Houston and when it rains it would help alot. Any one know the cost of having it put back in or what I could do to be able to control to the traction.
#38
Originally Posted by Phynix
acctually you can add it, but its not easy
Come on, 3 or 4+ thousand dollars to add traction control? So I usually just tell people it's not something you can add.
Why would anyone want to add it if?
