Want new, brighter T/A fog lights
Originally Posted by Formula350
I'm no electrician but I think it'd be fine for 55w. Going to 100 I'd probably rewire them then. Just to be safe.
Wiring and bulb holder is what will melt
not a problem if you dont mind a little smoke.
I would use a relay and a fused wire from the battery.The old foglamp
circuit can power the relay.
Then you can put what ever you want in those fog lamps.
I didnt have foglamps(Firebird not TA) so I got the hella FF50s and put them in the foglamp holes
those are some serious lamps
Plus the kit gives you wiring and a relay.
