lt1 drivers side window
Old Sep 12, 2007 | 03:39 PM
ihaterice's Avatar
Exclamation lt1 drivers side window
HELP this is really annoying!!! i have been experiancing this for about a year now but it has been really bad the last couple of months. whenever i roll down my drivers side window it will go a few inches and stop, i then have to wait a few mins and try again and the same thing happens. this had happened in my friends 93 camaro but never got this bad. i have done a few chenck on the wiring and the switch and found those to be good. from looking at electrical diagrams a found that there is a electronic circuit breaker in the door with the window motor. has anyone else experienced this problem? and if so how do i fix it?
thanks, Matt
Old Sep 12, 2007 | 06:54 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
The window motor is bad.
Old Sep 12, 2007 | 07:10 PM
WS-Six's Avatar
yep your window motor is definitely on it's last leg. The same thing happened with all 3 of my birds, and had to replace a total of 4 motors lol. It sounds like you will only have maybe a few weeks to a month left with that motor, I would buy a new motor before it stops working all together and wind up having your window stuck rolled down. Here is an excellent walk-thru if you want to install it yourself:
http://shbox.com/page/windowmotor.html
Hope this helps
Old Sep 12, 2007 | 08:58 PM
t-rocks firehawk's Avatar
heck he's lucky mine lasted about a week after it started doing that.make sure you go back with rivets the nuts and bolts tend back off over time...
