Removing the coolant level sensor. '99 TA
Coolant level is fine, but it still shows on the driver console that the engine is overheating or the coolant is low, and the engine temp is running fine at 210 degrees, its when it gets to that 210 mark is when the light comes on. ive heard of 2 solutions, replace the sensor or just remove it
Done and done, and it turns out my car WAS running on overheat mode seeing how before i took it out, it only pulled til about 60-70 as opposed to now where it pulls to 85-90
Funny that your sensor went out on just about same time as mine! Mine's giving the senseless low coolant level warning too.
I can't bring myself to just unplug it so I want to replace it. Any tricks in getting it off and replaced? I figured I'd do it when I change the coolant on it.
Ran across this page just know showing howh to do it. Seems like its a simple clip holding it in place. Hope it helps me and other!
http://www.pharmacy.arizona.edu/staf...antsensor.html
Yeah you don't need to drain rad to install it. I popped in another one and barely lost any coolant. I am getting th5e message again though mabye am low now. Will check again in spring. If not will disconect it. I wonder if the car goes into limp home mod when it comes on?
Al, I have been running with my low coolant sensor unplugged for 6 years or so now. It kept getting corroded and gummed up and I got two new ones put in and then I cleaned them another couple of times after that and then I finally said screw it and I pulled the connection off to the sensor. You just have to check your coolant manually every once in a while to make sure it is full.
