blinker problems
For the DRL/turn signal lights, you can reach through the opening in the front fascia that's right under the light housing, or you can access them from the black plastic panel underneath the car.
Also, I thought that if a DRL/turn bulb or socket is bad neither the dash indicator or tail light will flash? However on my car they are flashing even without the DRL/turn signal...
