Siphon gas?
Hello Everyone.
I have a 75 Firebird Esprit.
Car has been sitting for at least 5 years. It has half a tank of gas in it and I want to get it out and put fresh fuel in. Problem is, I cannot just siphon it out. There is what I am guessing is and anti-theft device in the tank. I cannot stick anything down the tube. There is a spring type device in there blocking everything but liquids from going down the tube.
Any suggestions for how to get the gas out?
Option 1: Take tank off.
Option 2: ...
Thanks
Myles
Option 2: ...
Thanks
Myles
if the fuel filler neck is all metal (which i think it is), there isnt much you can do. if its partly rubber, then you can disconnect the neck from the tank. inside the neck is where the anti-siphon part is. you can then stick a tube in the tank itself to siphon. otherwise, you may have to drop the entire tank/filler neck assembly as one, and take it apart from there.
