Firebird Production Number, Color Breakouts, Options, Etc.....POST QUESTIONS HERE!
#365
Please help with this one. 1994 Formula Firebird In purple pearl metallic. All my research turned up was 4789 hard top Formulas in 94, so how many were in that color? I know it is a rare color, but can't find the numbers on it.
#366
I just found an automatic VIN decoder and ran my car through and found out mine is pretty rare. one of only 76 cars with a special sticker setup for Hawaii. I assume that means only 76 cars were shipped to hawaii in 1995. i wonder how many of them were Trans Am's.
http://www.compnine.com/vid.php
VH3 LABEL INFORMATION BUMPER IMPACT,5 MPH,HAWAII 5 MPH IMPACT INFO LABEL FOR BUMPER-HAWAII(VH3) 76
and my car was built on 10/11/94.
theres also an rpo R9Z that is unknown that had 221 units.
according to the report my car is a 1 of 1
Vehicle: FIREBIRD 2 DR
Year: 1995
Build Date: 1994-10-11
Found 49,204 vehicles matching your year and model in our database.
RPO Description Matches
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
49,204
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
35,058
UT6 RADIO,AM/FM STEREO,CASSETTE,EQUALIZER,ETR,CLOCK STEREO CASSETTE/EQLZR(UT6)
19,497
UW2 SPEAKER SYSTEM -10, QUAD FRT DR MTD, DUAL RR SAIL PNL, AMPLIFIER 10 SPKR SYS(UW2)
35,058
U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75)
ANTENNA,POWER(CHROME) PWR ANT(U75)
35,058
76
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
35,613
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
47,438
WS9 MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
20,825
Y82 TRANS AM PKG BASE(MERCHANDISING OPTION) PKG,TRANS AM BASE(Y82)
13,072
1SA PACKAGE-OPTION 01 (1SA)
13,863
12I INTERIOR TRIM GRAPHITE (12I)
33,974
122 TRIM COMBINATION LEATHER,GRAPHITE (122)
9,128
41Q MOLDING COLOR,BLACK (41Q)
9,009
41U EXTERIOR COLOR,PRIMARY (41U)
EXTERIOR COLOR,PRIMARY,BLACK (41U)
9,207
6HD COMPONENT FRT LH COMPUTER SEL SUSP (6HD) SUSP(6HD)
17,850
7HD COMPONENT FRT RH COMPUTER SEL SUSP (7HD) SUSP(7HD)
17,850
8TH COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
18,393
9TH COMPONENT RR RH COMPUTER SEL SUSP (9TH) SUSP(9TH)
18,393
AAA Unk. 44,587
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3)
34,540
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
49,204
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
10,622
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
32,116
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
42,101
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
41,652
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
47,924
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
47,965
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
29,873
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
43,601
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
48,953
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
20,578
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
40,492
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
44,586
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
20,825
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
45,444
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
31,842
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
21,750
IL2 TRIM,INTERIOR DESIGN (IL2)
9,585
J1F BRAKE,SPECIAL(EXPORT) SPECIAL BRK(J1F)
21,841
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
21,750
KG9 GENERATOR,140 AMPERE 140 AMP(KG9)
20,825
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
42,586
LT1 ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
20,825
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0)
36,156
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
36,156
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
45,836
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
35,613
N60 WHEEL(ALUMINUM)(PAINTED) PAINTED AL WHL(N60)
20,640
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
10,365
R9Z Unk. 221
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
49,204
T43 SPOILER,REAR RR SPLR(T43)
10,470
T96 LAMP,FRONT FOG FRT FOG LP(T96)
LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
12,846
-- 0
Rarity...
There are 1 1995 FIREBIRD 2 DR vehicles (0.002%) matching your exact options list. There are 1 (0.002%) with at least as many options.
The rarity of your vehicle is based on an exact match of your options for your year and model.
Year: 1995
49,204
35,058
19,497
35,058
35,058
76
35,613
47,438
20,825
13,072
13,863
33,974
9,128
9,009
9,207
17,850
17,850
18,393
18,393
AAA Unk. 44,587
34,540
49,204
10,622
32,116
42,101
41,652
47,924
47,965
29,873
43,601
48,953
20,578
40,492
44,586
20,825
45,444
31,842
21,750
9,585
21,841
21,750
20,825
42,586
20,825
36,156
36,156
45,836
35,613
20,640
10,365
R9Z Unk. 221
49,204
10,470
12,846
-- 0
Rarity...
#367
Just got off the phone with SLP, and my car is build number 555 of all the TA and Formula WS6s. They said after 96 GM wanted to retain all the records so SLP sent them back to GM after the cars were completed. They dont have a break down between Formulas and TAs though
SO the answer is Yes SLP did the LT1 WS6s and only kept records in the beginning.
#368
But HEY, got it bookmarked and will play with it some more. THANKS, that's a great find!
#371
WOW! That is COOL! Have you checked the accuracy of the info it spits out on your car? This almost seems to be like (if not even better giving "rarity stats") the GM-VIS system I've been dying to get access to. However, I'm not sure if it's really fair to be calculating the "rarity" based off each and EVERY RPO code listed for your car. Most "authorities" on collector car rarity limits this to year, model, body style, engine, transmission and *maybe* body paint color. Things like delay wipers, # of cigar lighters and audio system aren't generally accepted as qualifiers for determining rarity.
#372
Check this out. Seems those smart & kind folks at CompNine.com knew what I was wanting to do: filter their database using RPO codes to extract breakdown numbers. While plugging in VIN#s for the few '98 WS6s that I did have in an attempt to generate color/trans breakdowns for the small amount of cars I could, I stumbled across a link to a page that allows me to filter their database. After 3 days of pounding their server to extract this data, I was able to generate the previously non-existent color/option breakdown for the 1999 Firebirds, including WS6, 30ths, 1LEs and Firehawks. I decided to start with a "clean slate" and pull all of the numbers from a single source, rather than trying to "reconcile" and format inconsistent data from several sources. I've attached a screen shot of what I've done (so far, I'm planning on doing the same for the rest of the 4th gen years, and maybe even Camaros eventually).
Check it out and let me know how the format works. I've broken it down to the level of transmissions for the V8 cars, which is more detail that I've seen from the majority of other data sources.
EDIT: Cleaned this up, added AQ9 data and .PDF'd.
12/14 edit: Added exports and moved to later post.....
#373
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
pretty cool- info on my Formula-
Rarity...
There are 1 1998 FIREBIRD 2 DR vehicles (0.003%) matching your exact options list. There are 2 (0.007%) with at least as many options.
To check any combination of RPO codes to find how rare your vehicle is based on the most important codes, click here.
so total gold Formulas- 62
43 t-top cars and 19 hardtops
48 had grey cloth interior
41 had the standard painted 16" wheels
GU2 2.73 gears- 30
GU5 3.23 gears- 14
GU6 3.42 gears-18
A4- 44
M6- 18
WS6- 6 (2 automatics and 4 manuals) includes the 1LE car, the non 1LEs are all t-top cars
1LE- 1 (hardtop M6)
Rarity...
GU2 2.73 gears- 30
GU5 3.23 gears- 14
GU6 3.42 gears-18
A4- 44
M6- 18
1LE- 1 (hardtop M6)
#378
Here's the 2001s in .PDF. You might have to right-click/save-as and then open it from your hard drive.
I'm going to add more detail to the '99s and '00s for the AQ9 seats like I did on the '01s before I upload .PDFs of them.
Once I get all the years done, I'll put them in one new post and ask the admins to sticky it.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
EDIT: Added 1SH (NHRA)
#379
Are you taking into account the export cars?
I only ask cause I went through the 1998 birds on Compnine site and found my numbers differed from many posted numbers till I took out the Z49 and CW7 export cars. For 1998 the production number I have seen has been 32,157 but through compnine I get 32,947 (30,710 coupes and 2264 convertibles). That number doesnt match untill I remove the Z49 Canadian cars (592 coupes and 145 convertibles) and the CW7 PR/Virgin Island cars (80 coupes).
For example in bright green metallic the number I've always seen has been 631 produced instead I get:
1998 Bright Green Metallic = 640 total with 9 Z49 exports and no CW7 exports
Firebirds = 467 total (5 Z49 export)
Firebird Convertibles = 31 total (2 Z49 export)
Formula = 34 (no export)
Formula Convertibles = 0
Trans Am = 98 (no export)
Trans Am Convertibles = 10 (2 Z49 export)
HTH,
Steve
HTH,
Steve
#380
HTH,
Steve
HTH,
Steve
When I was initially punching in VIN#s for the '98 WS6s from my ASC list, I did stumble across a few that did not show up in their database. So either they were missed when they (or whoever they got it from) compiled their database, or the VIN# in my ASC listing was in error (I'd suspect the check-digit might have been off in a few VIN#s). Interestingly, my ASC list did not include the entire VIN# for ASC# 0001 (which was a purple T/A), so I took an educated guess by copying the first part of the VIN and began guessing the check digit and eventually stumbled across it. I've noted long ago the descrepancy between the #s listed in the '98 production from the ASC listing, the breakdown DrEvyl has posted shows only 2835 WS6s being built. Mine's #3030 and ASC claims 3086 were built so I've long known they didn't include something and suspected it was export cars. Hopefully once I complete the compilation of the '98s I'll solve that old mystery.
I haven't yet compared the production totals to other data sources to make any assessment on the "completeness" of Compnine's database, but I figure the data source with the higher totals is missing fewer cars and is therefore more credible.
