track time
ok i ran my g8 gt last nite for the first time i ran a 14.4 and then a 14.3 both at 100 mph i dont know what the problem is or what yea i live in south texas and it was high humidity and around 90 degrees outside does that have anything to do with it or what? help me out too slow..
dude were so low down here damn near sea level. so what would get my 60 foot time better would the vararam intake help that? cause ima wait to get a tune.
My best 60' was 2.216 - 1/8 8.8 - I havent tried on Idle I will try that next. 60' ft on
G8's are usually bad - I've seen some guys do a 60' 2.+ and get 12's on the 1/4 mile?? weird!! The numbers on these 4 door monsters are weird it all depends on your mods.
1/8 mile tracks do these cars no justice unless you have gears/converter/street slicks.
aite well thanks guys i guess i will jus play with it this friday at the track i jus dont understand why i would run a 14.3 when i have already put the full corsa exhaust on it that comes with the x pipe and stuff i jus dont know why i am not in the thirteens.
i suspect that just as with a GTO a catback isn't doing anything for you and is just an expensive sound mod until you get a lot higher up in HP. get a tune and on a cooler night you'll be in the 13s
Yeah, I've heard that the caback doesn't do much performance wise on a stock car. I'm probably going to do headers back to the axleback pipes and leave thse stock. I want the performance and a good sound, but not obnoxiously loud.
LS1 Tech Administrator
Unless you have a full engine and tranny tune, you're leaving at least a half second on the table in ET. You would be amazed how much timing is pulled at the starting line. The tune on my G8 made a night and day difference.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I ran my car with stock tune numerous times in hot humid weather in edinburg but it always ran 13.9 or better. After like 5k and a tune it dipped into 13.2x. If your going to the track in edinburg hit me up and i can check it out for u so u can see exactly what's going on with the scanner. I suspect your torque management is holding u back. Try using the paddle shift mode that sometimes helps.
