New Best 11.793 @ 117.59
Nice collection of HP you have. Since I know the G8 is not the fastest, which one is?
#35
So I guess you are pissed? I don't see your car going from 11.97 down to the low 11.30's, unless you spray it with a 75-100 shot. Did you stop and put your car on the scale at the end of the track?
It's a lot easier running your car on the internet than taking it to the track and running it?
#36
It will go low 11s. I havent changed gears yet(went through the traps in 3rd), it will take a bigger tire(blew the tires off trying a 2500 rpm launch).
That 11.974 was the 1st pass on a new combo. You being the expert you are you should know you are not going to get your fastest pass on your 1st pass.
I said it would run 11s on the 1st pass.....IT DID! Quit hating.
#40
