Gforce1320 1000hp 4340 axles install/review
Price: 1399 plus shipping
Weight: ****** Heavy
Tools Needed/recommended:
Sockets-12mm,18mm,22mm,32mm,36mm
Wrenches-12mm,18mm
Ratchets-3/8 drive air w/2" extension
Breaker Bar- 1/2
Impact Gun 1/2drive
Air Hammer with pointed bit
Dead blow hammer/rubber mallet
Hammer and punch
Long flat head screw driver/pry bar w/flat tip
Jack and 2 jack stands(one for safety the other as a extra set of hands)
Time to install 2 axles:3 hrs( 3 beers 10minutes on the phone with George and washed my hands 3 times during the swap)
1: Jack up one side and support it with the jack and 1 stand
2: remove tire 22mm
3: use the hammer and punch to relieve the notch on the not and remove axle nut 36mm
4:remove caliper 12mm and disconnect abs wire
5:remove caliper holder 18mm and rotor(optional but it's worth it)
6:remove the three bolts connect the hub to the toe rod,lower control arm, trailing arm
and loosen the one that connects the top control arm. 18mm
7: use the air hammer w/pointer tip to push the axle from the hub(do not hammer anywhere except at the indentation on the axle)
8: remove the upper control arm bolt and place hub on floor support axle with 2nd jack stand.
9: use the large screw driver/pry bar to pop the axle out.
10: line the new axle up with the diff splines and push it(once lined you need to give it a good push in to get it set in)
11: line up the outer splines with the hub and push it in far enough to have 1" of thread exposed(use jack stand to help support axle while you line it up)
12: reattach hub to upper control arm
13: use the impact gun and 32 mm socket to set the axle into the hub.
14:reattach the trailing arm,lower control arm,toe rod(in that order)
15: connect abs wire and place rotor on
16:reinstall brake caliper and carried
17: remove jack stands and mount wheel
18: move all your tools to the other side and have a beer.
I don't think I missed anything and it's not an easy walk in the park..But if have the tools and patience you'll be fine.
Wrenches-12mm,18mm
Breaker Bar- 1/2
Impact Gun 1/2drive
Hammer and punch
2: remove tire 22mm
