Pretty good day at the track...
No new personnel best in this hot muggy crap (2000+ DA) but I ran 11.53-11.58 on motor 3 times in 10 minutes! So close! The new gear makes it so easy to run 1.5 60' which gets the car moving! Can't wait to see what it runs in cooler weather, drag times had the DA correction at .2-.3 and I changed clothes twice just sweating the whole time.
It rained this morning and the track wouldn't hold the car the first few passes so I parked and let the sun do its job. Went back out a little later and the car dead hooked every time!
Our club also had 4 other G8's at the track ranging from mild cam/heads to just boltons. Most were in the 12.8-13.1 range for the three modded GT's and the M6 GXP (his first time to the track) also got a 13.1 I believe. I think everyone had a good time!
LS1 Tech Administrator
Sweet times in high DA. You will be in the 11.20s once you get some mine shaft air. Congrats.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Everything worked very well with the 9"! I got 3.70's and a spool which I believe makes the drivetrain a bit lighter and more efficient. She leaves so straight and hard with the spool, I love it. An NA only car would be fun with 3.89 or 4.11 gears on proper tire. I chose 3.70 since I dont want to go into 5th on spray. I thought the Camaro 3.45's were fun but the car wants to jump out of its skin with the 3.70's.
NICE! Good to see the combination is working good for you, especially in the heat. How high are you turning your motor? Don't know how "slow" you plan to run on the spray but with 3.45's I am already turning 6600-6700 thru the traps in 4th running a 27" tire. If you want to medal in this event, plan on 5th gear or 7200. To turn mine up any higher, I will need to upgrade to dual springs. Mine will float the exhaust valve past 7000.
Might have to upgrade to a drag pack this Fall to stay with the pack.
