2009+ CTS-V Brembo 6 Piston Front, & CTS-V Brembo 4 Piston Rear Upgrade DONE!
#43
"The Factory Parking Brake is not retained with just these items, you will need to acquire the custom Parking Brake Shoe from Adam@Squash (currently being produced)"
Are the parking brake shoes made to order? And where did you get those black Pontiac center caps?
#45
^^^Use a line wrench to crack the nuts loose on the cross over tube and remove the bleeder screws from the other side and switch them. I had to do this with the CTS-V rears on my G8.
#51
Hey guys,
I have had this mod wrapped up for 2 weeks now on the car. I cannot smile big enough at the improvement it made. I am gonna go to the shop and do a few things tomorrow, I'll have the wheels off the car, so I will snap some more pics and gather my PN list and post it here in this thread for all of you looking to do this upgrade...
Here are the PN's I used and other aftermarket products
FRONT;
REAR;
PRODUCTS ALSO USED;
Brake System Torque Specs
**NOTE**
As some of you know, I am a Service Manager at a GM Dealer, in which I pay 10% over cost, BUT THE ONLY GM PARTS I bought at my price level was the Brake Pad Pin Kits as they weren't avail through the online options I purchased everything else from cheaper than I could at my price level...Do the homework and you too will have the upgrade done for around $1700-1900 complete (now this is me doing the install) so you may have added cost involved if you can't do it yourself.
I did the following along with it;
I powdercoated the SFC, SwarBars & Tunnel Brace the same color as the Calipers...The decal is Matte Black
Attachment 613592
Attachment 613593
Attachment 613594
Attachment 613595
Attachment 613596
Attachment 613597
Attachment 613598
Attachment 613599
Attachment 613600
Attachment 613601
Attachment 613602
Attachment 613603
Attachment 613604
Attachment 613605
Attachment 613606
Attachment 613607
Attachment 613608
Attachment 613609
Attachment 613610
Attachment 613611
Attachment 613612
Attachment 613613
Attachment 613614
Attachment 613615
Attachment 613616
Attachment 613617
Attachment 613618
Attachment 613619
Attachment 613620
Attachment 613621
Attachment 613622
Attachment 613623
Attachment 613624
Attachment 613625
FRONT;
- ACDelco 177-1105 OE Service Front Brake Rotor - Qty 2
- ACDelco 172-2488 OE Service Front Brake Caliper- LH
- ACDelco 172-2487 OE Service Front Brake Caliper - RH
- Front Brake Caliper Pin Kit - 25940448 - Qty 2
- Hawk HPS 08+ CTS-V Brake Pad Kit
- Edelbrock/Russell 639560 Speed Bleeder - 2 Kits
- M14x2.0x40 Flange Bolts (Fastenal) - Qty 4
- Flat Black CTS-V Vinyl Logo
REAR;
- ACDelco 177-1051 OE Service Rear Brake Rotor - Qty 2
- ACDelco 172-2309 Caliper Assembly - LH
- ACDelco 172-2308 Caliper Assembly - RH
- Rear Brake Pad Pin Kit - 89047728 - Qty 2
- Andy @ Squash Performance Rear Caliper Bracket Kit w/ Bolts
- Hawk HPS CTS-V Brake Pad Kit
PRODUCTS ALSO USED;
- Russel Stainless Steel Braided Brake Line Kit
- ATE' Super Blue Brake Fluid
- Front Caliper Bolts - 129lb-ft
- Front Caliper Bridge Bolt - 24lb-ft
- Front Caliper Bleeder - 124lb-in (10lb-ft)
- Front Caliper Banjo Bolt - 36lb-ft
- Rear Caliper Bolts - 96lb-ft (including adapter bracket)
- Rear Caliper Bleeder - 115lb-in (9.5lb-ft)
- Rear Caliper Banjo Bolt -36lb-ft
**NOTE**
- The Factory Parking Brake is not retained with just these items, you will need to acquire the custom Parking Brake Shoe from Adam@Squash (currently being produced)
- Make sure you use New Copper Washers, I did not use the washers supplied with the Russel Kit as they were not Copper
- The factory G8 steering knuckle Caliper Mount holes will need to be drilled out to 14mm. Any machine shop should be able to do this for you (Mine were done for $10)
- BMR Subframe Connectors with Tunnel Brace
- BMR Full Sway Bar Set
- Eibach Spring Set
Attachment 613592
Attachment 613593
Attachment 613594
Attachment 613595
Attachment 613596
Attachment 613597
Attachment 613598
Attachment 613599
Attachment 613600
Attachment 613601
Attachment 613602
Attachment 613603
Attachment 613604
Attachment 613605
Attachment 613606
Attachment 613607
Attachment 613608
Attachment 613609
Attachment 613610
Attachment 613611
Attachment 613612
Attachment 613613
Attachment 613614
Attachment 613615
Attachment 613616
Attachment 613617
Attachment 613618
Attachment 613619
Attachment 613620
Attachment 613621
Attachment 613622
Attachment 613623
Attachment 613624
Attachment 613625
